After the second sharpening:
Resharpening went very well. I left my platform pre set on a support bar. I also left the micreadjust set. All I had to do was drop the support bar and platform in the sleeves and tighten.
Most of the time, the ACC solution would already be made up. Today I mixed up 150ml water + 6ml ACC. The T8 can work with 125+5 ml. The extra will not cause any spillage and will lessen the effect of evaporation. Support told me that it is water that evaporates, not ACC. When I was through sharpening, I just lowered the T8 water trough.
I switched to the DF-250 600 grit wheel. Four light round trip passes on each side did the job. I should have more scientific; fewer passes might have sufficed. I finished up using the leather honing wheel. I used another support bar, however, my second platform was cut and modified to be two small platforms. I plat to get another platform so that I can leave both support bars set up. (At this rate, I will soon run out of support bars.
The skew tended to lunge forward with the leather honing wheel. This may have been because of being trailing edge with the leather wheel. Using a standard platform might help. I will try that next time.
The journey is proving longer than I initially anticipated, however, I am making progress.
Soon there will be a slight detour in this process. I live near Rich Colvin. Rich is a very experienced turner. I want to learn his thoughts on the three diamond wheels and Multi Base. I plan to leave the three wheels and Multi Base with Rich for an in depth field test. During that time, I will be back to working with my old friend, the "Original" SG grinding wheel. That should actually provide a more interesting topic, as the SG is our standard wheel.
I will continue to keep posting.
