Author Topic: HSS Lathe turning tool  (Read 612 times)
Offline dusmif
  • Jr. Member
  • I'm a learning craftsman!
    • View Profile
« on: June 25, 2021, 09:00:58 am »
Hi, is it there a way to sharpen/modify Hss lathe turningb tools on the Tormek please?
Thanks
Alf.
Offline micha
  • Full Member
    • View Profile
Re: HSS Lathe turning tool
« Reply #1 on: June 25, 2021, 10:08:12 am »
Hi Alf,
are we talking about HSS bits for (metal) lathes? There are some with quite complex geometry, which might be hard to shape on the Tormek.
Simpler ones can be done on the SVS-50 or the SVD-110, depending on the geometry.
Yet shaping these from a HSS blank is quite time consuming. But just touching up an existing shape usually works quite well and might even work freehand.
The SB-stones may be better for grinding HSS, but it's not mandatory.
Mike
Offline dusmif
  • Jr. Member
    • View Profile
« Reply #2 on: June 25, 2021, 10:22:20 am »
Thank You Mike, I have the SVD-110, so I will give it a try.
And Yes correct, I am talking about HSS bits for the Lathe, yes some are very small,
Alf
Offline RickKrung
  • Hero Member
  • Maker
    • View Profile
« Reply #3 on: June 25, 2021, 04:09:33 pm »
Rich Colvin came up with a clever tool rest with a protractor as a guide for grinding HSS metal lathe turning tools.  He shows it in his Sharpening Handbook "Goniostat" section.  I attached one of his photos as a quick look.  He posted on this here on the forum, but I was unable to locate it.
I have several of these brass protractors and have been meaning to make one of these, but alas, I guess I just don't have as much need as I like to think.  I use a lot of carbide insert cutters and have two tools that use HSS inserts that I use for brass and aluminum.
Rick
Quality is like buying oats.  If you want nice clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes at a lower price.
Offline dusmif
  • Jr. Member
    • View Profile
« Reply #4 on: June 25, 2021, 06:38:36 pm »
Thank You Rick, very interesting and informative.
Alf
Offline RichColvin
  • Hero Member
  • Ornamental Turner
    • View Profile
    • SharpeningHandbook.info
« Reply #5 on: June 26, 2021, 05:05:47 am »
Thanks
Alf.
Alf,
The definitive source is Leo J. St. Clair's book from 1952 titled, Design and Use of Cutting Tools. He was working in the industry as it was changing from HSS to carbide, so both are covered well. His expermental data helps validate or disprove many theories. Unfortunately, this book is hard to find.  It took me 3 or 4 yrs before I finally found one on eBay which I immediately snapped up.
I summarized Leo’s work on the Sharpening Handbook at this link : https://sharpeninghandbook.info/index-MW.html
I use these approaches often.
Kind regards,
Rich
« Last Edit: June 26, 2021, 05:09:15 am by RichColvin »
Rich Colvin
Offline RichColvin
  • Hero Member
  • Ornamental Turner
    • View Profile
« Reply #6 on: June 26, 2021, 05:07:17 am »
Thanks
Alf.
Alf,
Kind regards,
Rich
Rich Colvin
Offline dusmif
  • Jr. Member
    • View Profile
« Reply #7 on: June 26, 2021, 12:10:36 pm »
Thank You very much Rich for your reply and the link, much appreciated.
Very helpful information.
Alf
Offline Ken S
  • Moderator
  • Hero Member
    • View Profile
« Reply #8 on: June 26, 2021, 10:07:07 pm »
Alf,
I happened to have several new metal lathe tool bits. I tried to use identical bits (same alloy). I put a bit in my square edge jig set for a 30° bevel. I set a timer and grind for five minutes. Comparing the post grinding bits is a good way to see the difference in how different grinding wheels cut.
The champion is the Norton 3X 46 grit wheel. Tormek makes no comparable coarse wheel.It is not a general purpose wheel and it is not "plug and play". It does remove a lot of steel quickly. The largest diameter is 200 mm. It works perfectly with the T4 and as well as a 250mm wheel worn to 200 mm with the T8.
Offline RickKrung
  • Hero Member
  • Maker
    • View Profile
« Reply #9 on: June 27, 2021, 01:11:39 am »
...snip...
"Broken Record Rick", I'll go further than Ken.  I also use this type of "traditional" grindstone on my Tormek, a T8.  I initially used a Norton 3x 64 grit wheel, based on Ken's recommendation.  It worked great and was my go-to grindstone for heavy metal removal.  I have available and set up for use with Tormek jigs, a Viel belt grinder and a Rikon slow speed grinder, but the traditional grindstone preserves the consistency of the wet grinder function and avoidance of any chance of heat damage.  These grindstones can be trued using the truing tool, which I highly recommend.  I use a diamond dressing tool to refresh them, but that is seldom needed, as is truing once the are trued initially.  I have not used these grindstone for HSS, but they should work just fine as they are made for use with HSS at high speeds.
As Ken mentioned, they are not "plug and play", requiring a custom bushing to adapt the usual 1" arbor hole to the 12mm Tormek shaft and flange washers to support and align the grindstone and to take up the additional space on the shaft for the difference between the Tormek 2" wide wheels and the Norton style grindstones at 1" width.
All of this has been discussed on a variety of prior posts, by Ken and myself.  I have not heard of others who use these, however.
Rick
« Last Edit: June 28, 2021, 05:40:16 am by RickKrung »
Offline Ken S
  • Moderator
  • Hero Member
    • View Profile
« Reply #10 on: June 27, 2021, 02:37:47 am »
Rick,
I have reshaped hss turning gouge and skew with the Norton wheel. Also the lathe tool bits I use for testing are at least hss (M2 or above).
Did I mention that a Norton 3X only costs about $50US! That's a lot of firepower for not much money.
Offline dusmif
  • Jr. Member
    • View Profile
« Reply #11 on: June 27, 2021, 11:41:52 am »
WoW, than you guys, most helpful.Much appreciated.
Alf.
